vcCustomDof
vcCustomDof
Parent: vcDof
JointvcMatrixExpressionPropertyR
Access expression value via vcMatrixExpressionProperty
Gets the expression property that, when evaluated, returns the joint definition of the joint. VALUE can be used to reference the current value of the joint, for example "VALUE+10".
PivotvcMatrixExpressionPropertyR
Gets the expression property that, when evaluated, returns the pivot point definition of the joint. VALUE can be used to reference the current value of the joint, for example "VALUE+10".
